Board's jointed edge uneven
greasemonkey2275
Post by greasemonkey2275 »
It has been a while since I have been on here let alone a while since I had my Shopsmith running but I cannot figure out why I am getting an uneven jointed edge. I have checked the jointer faces and blades and all are true and even yet when I make a pass across the jointer, I end up with low spots and high spots. Looking for any insight as to what I am be doing wrong.
Jake
Spokane, WA
rjent
Re: Board's jointed edge uneven
Post by rjent »
How much material are you trying to take off at a time? I have found the less material the smoother the edge. Also, in what plane are you have a problem with. Are you getting highs and lows in the edge, or an edge not 90 degrees to the perpendicular.
Just the first questions LOL
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
Dansmith
Post by Dansmith »
greasemonkey2275 wrote:It has been a while since I have been on here let alone a while since I had my Shopsmith running but I cannot figure out why I am getting an uneven jointed edge. I have checked the jointer faces and blades and all are true and even yet when I make a pass across the jointer, I end up with low spots and high spots. Looking for any insight as to what I am be doing wrong.
When you say "low spots and high spots", are you referring to a ripple effect?
greasemonkey2275
rjent wrote:How much material are you trying to take off at a time? I have found the less material the smoother the edge. Also, in what plane are you have a problem with. Are you getting highs and lows in the edge, or an edge not 90 degrees to the perpendicular.
I am removing about 3/32" per pass and tried 1/16" and still had the same problem. I am trying to establish a flat edge on several pieces of resawn walnut; each piece is no more than 28" long.
Jake
Spokane, WA
greasemonkey2275
Dansmith wrote:When you say "low spots and high spots", are you referring to a ripple effect?
Not the ripple effect; the ends of the board are low and the center is high over a 28" pass.
Jake
Spokane, WA
rjent
Post by rjent »
Try cranking it down (up) to a 1/64 th or so and see what happens. How are you feeding the stock (pad, push sticks, ??), and are you using the featherboard.
Some pictures of the machine and the stock would help ... :)
Dick
1951 jigsaw X 2
If the blades in the cutter head do not all rise above the table surface by the same amount you will get a ripple effect as each blade cuts to its own depth.
Make certain that the blades are properly adjusted (same depth of cut).
Just curious, what method do you use to adjust the blades?
greasemonkey2275
rjent wrote:Try cranking it down (up) to a 1/64 th or so and see what happens. How are you feeding the stock (pad, push sticks, ??), and are you using the featherboard.
I tried cranking it both up and down 1/64" and nothing seemed to help.
Jake
Spokane, WA
greasemonkey2275
dusty wrote:If the blades in the cutter head do not all rise above the table surface by the same amount you will get a ripple effect as each blade cuts to its own depth.
I am not having a ripple issue; the blades were adjusted per one of the forum posts.
Jake
Spokane, WA
You are not keeping the just planed edge tight to the OUT feed table.(assumes the blade height coincides with the outfeed table height). Once there is sufficient 'new' surface to assure alignment to the outfeed table, NO downward pressure should be exerted towards the infeed table.
Also the tables need to be 'coplaner'. Raise the infeed table until it is the same height as the outfeed table. A straight edge should touch all points on both tables regardless of it's position. The blades should 'just touch' that straight edge at their highest point.
When a workpiece is initially held tight to the IN feed table, the freshly cut end of the workpiece should just barely clear the leading edge of the OUT feed table and not rise above the OUT feed table as the workpiece moves forward. Once downward pressure is being applied to the OUT feed end, the trailing edge may properly ride above the IN feed table. If the workpiece is then forced down tight to the IN feed table the rocking chair rocker bottom effect will take place. ;)
