new guy, needs guidence...
william
Post by william »
Hello All,
Dad,sadly enough, has left me his shop smith, mark v. I have been cleaning it up and checking everything out and cannot seem to figure out how the the power plant attaches to the band saw? I have mount locks but they do not fit each other. Can any one tell me which ones I need to order? thanks for your time, William
cincinnati
Post by cincinnati »
http://www.shopsmith.com/ownersite/cata ... oupler.htm
This is what you should have.
Here is another helpful link
http://www.shopsmith.com/academy/
william;
The following link shows the power coupler and hubs that are needed to attach the bandsaw to the Shopsmith headstock (power plant).
http://www.shopsmith.com/ownersite/catalog/powercoupler.htm
This one shows the bandsaw mounted on the left end of the Mark V with the table saw sitting to the right side of the headstock. The power coupler for the bandsaw is in between the bandsaw and the headstock.
http://www.shopsmith.com/ownersite/catalog/bandsaw.htm
I'm sorry your father isn't there to help you with this. Please don't hesitate to seek assistance here; it is the least I can do. Good luck in your efforts to put dad's Shopsmith back into productive service.
nuhobby
Offset tubes perhaps
Post by nuhobby »
william,
We hope you enjoy these machines and continue to honor your dad's memory.
FYI, in addition to the prior posts, sometimes a very old bandsaw is sitting on "straight tubes" rather than eccentric-offset tubes; see item 51 in the drawing here:
http://www.shopsmith.com/ownersite/part ... pview1.htm
If you have the correct eccentric tubes, then your bandsaw can be adjusted both in height and in horizontal offset, to line up just right with the upper left output shaft of the Mark V powerplant.
Chris
william
Many thanks.....
Post by william »
Cincinnati, Dusty & Nuhobby,
Wanted to thank you guys so very much for the help, have ordered the new mounts and can't wait to start working on some projects.Will be in touch as I progress, thanks again. William.
james.miller
Post by james.miller »
Check to see if Shopsmith is going to have a Traveling Academy in your area. Attending one is very valuable in learning to use the Shopsmith.
http://www.shopsmith.com/ownersite/trav ... gister.htm
Jim in Tucson
