Belt Sander Pivot / Tilt not working
CAP
Post by CAP »
I recently purchased a used Mark V510. One of the accessories is a belt sander, I am having difficulty figuring out how to tilt it. It is current in the straight up position, what do I do to allow it to lay down in the flat horizontal position?
Re: Belt Sander Pivot / Tilt not working
Two things - Remove the bolt that prevents it from tilting. - Loosen the nut that provides tension.
rpd
Post by rpd »
You can down load a manual for the belt sander here. http://vintagemachinery.org/pubs/747/6083.pdf
