Bandsaw Speed
agleason
Bandsaw Speed
Post by agleason »
What is the recommended speed setting for the bandsaw? So far i have kept the SS 520 in the lowest speed when operating the band saw. Any suggestions would be appreciated.
Sent from my SM-G955U using Tapatalk
50th Anniversary Mark V Model 520
Bandsaw, Jointer, Beltsander
algale
Re: Bandsaw Speed
Post by algale »
It depends both on what you are cutting and what kind of blade you are using (both width and tooth per inch count). Power Tool Woodworking for Everyone has a section with recommended speed combos.
http://www.shopsmith.com/academy/bandsa ... htm#speeds
agleason
Re: Bandsaw Speed
Post by agleason »
algale wrote:It depends both on what you are cutting and what kind of blade you are using (both width and tooth per inch count). Power Tool Woodworking for Everyone has a section with recommended speed combos.
Thanks so much, exactly the info i needed.
stickmaker
Re: Bandsaw Speed
Post by stickmaker »
These are the band saw speeds in Mark V speed cart I go when I got my 520. Hope it is helpful.
bs chart.jpg (200.53 KiB) Viewed 14653 times
Randy
Simer Fi
WE LIVE IN THE LAND OF THE FREE BECAUSE OF THE BRAVE!
