Motor belt broken
Dustyrose61
Motor belt broken
Post by Dustyrose61 »
Hi everyone,
I was wondering if anyone could give me some advice on what would cause the belt to break?
Thank-you,
Dennis
Re: Motor belt broken
It is old and dried out? ;)
Dustyrose61
jsburger wrote:It is old and dried out? ;)
Thank-you for the quick reply, I tried to post a picture but it said that it was too big file size.
Yes it looked dried out . I also had too change the off/on switch as well. I was thinking that I didn’t get the dial gear to go on very good at first.
Dennis
Dustyrose61
Falcon 001 043.JPG (151 KiB) Viewed 7307 times
That is far beyond old and dried out. :eek: Dry rotted and crumbly comes to mind.
Do tell us about the dial gear. :confused:
Dustyrose61
Hi there,
As far as I could see that when I put on the dial in I should have taken the cover off the back of the machine and put the clip on from that side. It’s been awhile since I worked on the machine,so I kind of forgot that. Once I put the clip on properly it worked fine for about a few minutes,by then the damage was done.
Dennis
Dustyrose61 wrote:Hi there,
Dennis
Well that explains it! :)
Yes the back access is much easier!!! :cool:
I just did not understand why the dial would be removed to replace the belt. ;)
