Disposing of Used Solvents
john_001
Post by john_001 »
What do you do with solvents like mineral spirits or alcohol after they've been used to clean brushes or other things?
garys
Re: Disposing of Used Solvents
Post by garys »
I avoid cleaning brushes whenever possible. I use the cheap foam brushes and throw them away when they are no longer useful. Between uses, I wrap them in aluminum foil and store them in my deep freeze. Once the brush starts to dry up in storage, it goes in the trash.
bainin
Post by bainin »
Down here- we have the city dump which accepts them as household chemicals.
beeg
Post by beeg »
I have three cans, #1 I keep mineral spirits in it. #2 I keep brush cleaner in it. #3 is an empty can, that I pour which ever cleaner I'm using into it. When finished with that cleaner. I pour it back into the original can and let the solids settle out. So that next time I can pour the clear fluid in to #3.
benush26
Post by benush26 »
Summer time I pour the used liquid into a large disposable aluminum pie plate outside and let the liquid evaporate. Fall and Winter I double line a 5 gallon bucket (that you buy from HD or Lowe’s) with plastic garage sacks, fill with kitty litter and a paper based fluid absorber. Pour in the fluid, let it dry and solidify, tie each bag. If your local garbage company allows disposal with regular garbage, then into the dumpster, otherwise a special trip to the city dump at some point. In the winter I’d probably leave it outside to keep the smell out there.
As a side note, I used to strain used liquid through a few layers of cheese cloth to reuse the liquid a time or two. Now I buy it in gallon containers and don’t worry about reusing it.
Hope that helps.
Be well,
Ben
john_001
Post by john_001 »
I like the idea of letting it settle and decanting the clean part. Thank you for the suggestion, Beeg.
john_001 wrote:I like the idea of letting it settle and decanting the clean part. Thank you for the suggestion, Beeg.
Realize if paint thinner, the solvent will absorb oils etc. from the paint and become less efficient. Great for cleanup use. Use fresh as a last step(replenteshes that which is lost).
john_001
Post by john_001 »
That's what I figured - it'd be good for preliminary brush cleaning, but not as clean solvent anymore.
