Shopsmith mandrel for pen turning
wgander
Post by wgander »
Is there a Shopsmith mandrel for turning pens? I saw one on a YouTube video, but can't find it on the Shopsmith site. If there is, please give me a link., If there isn't, is Penn State the best one to get?
joedw00
Re: Shopsmith mandrel for pen turning
Post by joedw00 »
That is where I got mine.
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
joedw00 wrote:That is where I got mine.
WHERE is THAT? Shopsmith or Penn State?
You might be able to save a few $ if you already have the shopsmith 1/4" router chuck. You can just buy the mandrel shaft (about $7 at woodcraft) and use the router chuck for the drive. That is what I do.
https://www.woodcraft.com/products/repl ... en-mandrel
If you happen to have the notion to buy a Lathe Pen Mandrel Saver you can then just buy drill rod and have a really nice set up. If you don't go this route then make sure you get a decent live center for the tail stock end.
pen set up.jpg (179.9 KiB) Viewed 17602 times
dms8667
Post by dms8667 »
I have had good luck with the Penn State mandrel and their mandrel saver.
mrgrigsby
Post by mrgrigsby »
dms8667 wrote:I have had good luck with the Penn State mandrel and their mandrel saver.
Which Mandrel saver did you get, when I spoke to them, they said the Mandrel saver would not work with Shop Smith?
rpd
Post by rpd »
7
The #2MT Mandrel Saver works just fine on Shopsmith s :)
