Homemade Shopsmith drumsander using a cardboard drum
MakinSawdust
- Bronze Member
Will a CARDBOARD drum work on a homemade drumsander? Can a bicycle hub be used as a drumsander bearing? Today I will show you the drum and how I change the sandpaper.
[youtube]https://youtu.be/-p7Fs2xmmKc[/youtube]
Re: Homemade Shopsmith drumsander using a cardboard drum
Cool idea, might even try it out. Cardboard tubes are so cheap I don't know if I'd bother peeling old paper off and just use a new tube instead.
[youtube]https://www.youtube.com/watch?v=-p7Fs2xmmKc[/youtube]MakinSawdust wrote:Will a CARDBOARD drum work on a homemade drumsander? Can a bicycle hub be used as a drumsander bearing? Today I will show you the drum and how I change the sandpaper.
Would PVC be an option to the cardboard drum?
- SkullsquadronX
I have seen two u-tube videos with a PVC as a drum sander. Going to use PVC when I make mine.
You might want to re-think the PVC pipe idea. Scott just posted a video about this very subject; seen in the link below:
https://www.shopsmith.com/ss_forum/comm ... ml#p275447
Chad Nevels
1963 Shopsmith Mark V "Goldie" 1-1/8 hp Serial # 379185
1980 Shopsmith Mark V 500
1994 Shopsmith Mark V 510
1994 OKUMA LB15 II OSP7000
2017 OKUMA LB3000 EXII SPACE TURN MY OSP P300LA
MakinSawdust
- Bronze Member
PVC is surely an option too. I have an abundance of cardboard tubes available for me, so this is why I decides to go that route.
My Motto: "Use what ya got and not what ya aint"
- thedovetailjoint
PVC isn't an awful choice, but the tubing I used sure was. It was actually tubing from rolls of kraft paper that Shopsmith used in the factory as packing material. The tubing was very thin-walled, so that was the biggest flaw. Schedule 80 or even 120 if you can get it would be amazing. Scott
Both PVC and cardboard might have the 'roundness' problem described in the video. A shorter drum might be less of a problem. In the video he ended up laminating plywood into long square stock and turning it, that seems like a much better solution than stacking up 40 or more disks although more work and cost than a pre-made pipe or tube.Chad wrote:You might want to re-think the PVC pipe idea. Scott just posted a video about this very subject; seen in the link below:
This post might be worth checking out even if the end product is quite different. It involves making a drum out of PVC and how I got it round etc.
https://www.shopsmith.com/ss_forum/begi ... t5342.html
BTW I still have and use this 10 years later.
