Request for Information
Would someone take a digital photo of their planer infeed cover and send it to my email address,cjcvontrappmeyer@aol.com I have an older machine which doesn’t provide any of the helpful information except for the warning information. Thanks
Re: Request for Information
Here you go.
- 20201022_142147.jpg (267.28 KiB) Viewed 4004 times
COULD SOMEONE ELSE DO THE SAME FOR A SS MOUNT PLANER??? PLEASE!!!
br549
Re: Request for Information - 12" Planer Label
Here's one.
- Mark V Mount Planer Label.jpg (1.27 MiB) Viewed 3940 times
My planer must be the "deprived" version. It doesn't have that decal. The only decal on mine is the warning decal that tells you to keep your fingers out of the cutting area. Very good advice.
THANK YOU!!!!br549 wrote:Here's one.
I don't have a SS Planer but I think I recall in the DIY PowerPro video Jim saying that one should request a new sticker for the Planer from the mothership. I don't know if that meant there were changes other than the speed setting. And I think I recall that the OP has a PP. Perhaps someone with both a Mark Mounted Planer and PowerPro can explain any changes.
For sure, one needs to know that the 'default' installation is different on a PP and that if you use the menu driven settings the Planer needs to be in the default position. Else, IIUC, the blades will be turning the wrong way. There are threads on this subject with a more complete explanation.
The mention of "T" speed setting would be non relevant with a PP.
- mountainbreeze
I don't have that sticker on my Shopsmith mounted planer either but looking at the sticker, I have to ask: If I have a 10" wide piece of softwood and I want to take off 1/32" per pass, the table says the maximum feed rate is 7. Seven what? Feet per minute? And my feed rate dial only indicates High, Medium, and Low so where would I set it to get "7"? Does the newer planer feed rate dials have numbers on them?
More detailed information appears in the manual:
mountainbreeze wrote:I don't have that sticker on my Shopsmith mounted planer either but looking at the sticker, I have to ask: If I have a 10" wide piece of softwood and I want to take off 1/32" per pass, the table says the maximum feed rate is 7. Seven what? Feet per minute? And my feed rate dial only indicates High, Medium, and Low so where would I set it to get "7"? Does the newer planer feed rate dials have numbers on them?
Yes.
