Nick/Drew's Thickness Jig question
kd6vpe
Post by kd6vpe »
Hello,
I just got my Conical Disk and have a question on building the Thickness Jig from the saw dust sessions. There is a support piece 3/4" stock that is 1 -1/53" high to form the 5 degree slope required for the jig to work does anyone know what the bevel is on the top of this piece is? Would that be 5 degrees? I know this might be a stupid question but I have done some stupid things in my learning and have decided to ask before I mess up anything new again. Thanks in advance. You ask what stupid I used my flat disk to do some thickness sanding and boy can the disk shoot wood out quickly if you put to much pressue on the piece. No damage but not doing that again have to try this jig.
SS 500 upgraded to 510; SS bandsaw; SS jointer
SS Oscillating Drum Sander; Universal Lathe Rest;
lathe duplicatior, shaper fence and shapers; SS Belt
Sander
Jim
www.youtube.com/kd6vpe
5 degrees??????
Where did FIVE degrees come from?????
The table angle Normally is set to FOUR degrees(=square to conical disk).
I don't remember "Nick's jig" so take this with a grain of salt as to whether it is relevant to the jig.:)
P.S. Re flat disk thickness sanding...Did you bias the fence so outfeed(back/moving upward) side has clearance?.....adjust screw on right side of fence toward table on 500..5x0(don't know)
8iowa
Post by 8iowa »
In one of the older editions of PTWFE, DeChristoforo described how "edge" sanding could be accomplished using the flat disk and an offset fence. This was before the days of the conical disk sander. I tried DeChristoforo's method, with mixed results. The conical disk provides much better results.
a1gutterman
Post by a1gutterman »
kd6vpe wrote:Hello,
Hi Jim,
I am a bit confused. I do knot see a jig when Nick is using the conical disk for thickness sanding: http://www.shopsmithacademy.com/SS_Archives/SS101/SS101_ConicaL_Sander.htm
Can you tell me where to look for it?
Tim
kd6vpe
Post by kd6vpe »
8,
Thanks I will look that up and see what is there I always forget about that darn book it has so much information in it.
Tim,
It was session #12 and the plans where on the blackboard.
Thanks guys I think it will be 5 degrees. I will go on that assumption for now. I need to do some thickness sanding on the rocking horse I'm working on and this is the perfect opportunity to try this jig, the SS sale was what made this all happen. I will report back on what happens thank you all for the help.
Sander
Jim
a1gutterman
I just went to SS#12 and still can knot see anything on the conical disk, including the blackboard plans. http://www.shopsmithacademy.com/SS_Archives/SS112/SS112_Index.htm
What am I missing?? :confused:
edit: It is SS#14. Am viewing it now.
Tim
a1gutterman
Jim, I think you are right about the 5 degree angle! Looking at the pdf plans, it shows that angle!
Tim
kd6vpe
Post by kd6vpe »
MYbad,
It session #14 good grief sorry for the confusion.
Sander
Jim
kd6vpe wrote:Hello,
You are correct in that the jig is built to introduce a 5 degree slope. It is also true that the conical disc introduces a 4 degree slope. Nick explains in the Sawdust Session (#14) that this was done on purpose knowing that a builder would probably not get an exact 4 degrees and would have to adjust the table tilt to acquire proper alignment.
Why did he not built it 3 degrees off then, why 5 degrees. Well, because in the vertical drill press mode the table only tilts one direction. Building it deliberately at 5 degrees (or greater) improves ones chances of being able to adjust out the builtin error.:eek:
I hope that makes sense.
Conical disk has a 4 degree slope. Jig has a 5 degree slope. Here's the blackboard item.- -
[ATTACH]2991[/ATTACH]
