Drill Chuck key holder
tfrayne
Post by tfrayne »
After neglecting my Mk V, as well as the rest of my shop, for about a year now, I am finally getting to spend some time in the shop. Last year seemed to be all about my project car....
I have two drill chucks for my Mk V. The one that came with it, and another that fits into the tailstock. That chuck will hold a bit stationary as the workpiece rotates. They each have their own chuck key, and they are not compatible with each other.
I had placed a large magnet on the back side of the headstock to hold them. And yes.... I get them mixed up all the time.
To correct this, I pained a thin yellow strip on the ShopSmith chuck, and painted the tip of the chuck key to match.
Then, I made a holder for both of the keys. The magnet was ugly but useful. I had a few scraps of curly maple and purple heart wood left over from a mallet I made awhile back. I did a quick glue up of the two and cut it to size. Then I drilled a recess into the back for the big ugly magnet. I then drilled into the top two holes that would cut into the recess such that when the keys are placed into the holes, they will contact the face of the magnet.
my apologies for the sideways photos, still haven't figured out photos....
drill chuck key holder.jpeg (55.68 KiB) Viewed 5315 times
Drill Chucks.jpeg (54.83 KiB) Viewed 5315 times
IT IS I, ENSIGN PULVER!!
AND I JUST THREW YOUR STINKIN PALM TREE OVERBOARD!!
STB
Re: Drill Chuck key holder
Post by STB »
tfrayne wrote: Mon Mar 20, 2023 10:14 pm
Glenn
edma194
Post by edma194 »
I have a magnetic tray on the headstock of my drill press. Just one chuck key but I keep two hex keys on there and have a simple way to tell what the correct one is: It will be the second one I pick up every time.
rpd
Post by rpd »
The trick with the photos is. always hold your phone in landscape mode, ie. long direction side to side, when taking them. I tend to set the aspect ratio as [1:1] myself, but that is just me.
The way the phpBB software handles photos is a bit different than the way most other software does, and the above is the only hassle free way to accommodate it's idiosyncrasies. Photo editing software will let you rotate the photos after the fact, but they don't all do it in a way that pphBB recognizes.
tfrayne
Post by tfrayne »
Thanks RPD!
