Dead animal in the shop
mbcabinetmaker
Post by mbcabinetmaker »
I have a dead animal somewhere in the back room of my shop that I cannot find. The stench is awful, I can hardly go back there without holding my breath. Does anyone know how to eliminate the smell?
Mark
2017 Power Pro Mark 7
paul269
Post by paul269 »
Breathe in through the mouth and out through the nose. Remove all decomp material first and all that it has contaminated. Then depending on the surface use odorxit.
http://www.odorxit.com/?odorxit-welcome ... DQodbQ6S_w
Kills primer does a good job of stoping odor too, but the surface must be cleaned first.
kalynzoo
Post by kalynzoo »
Lots and lots of ventilation. A couple of buckets of water and Pinesol may also help cover the odor to permit a thorough inspection of the area to remove the dead animal. Leave the windows and doors open and turn on the fans. Good Luck.
Gary Kalyn
Kalynzoo Productions
Woodworking
Porter Ranch/Northridge
Los Angeles, CA
fixit
Post by fixit »
This won't be a LOT of help but the only way I know about is to FIND the dead animal. I had a dead cat under our deck several years back. Fortunately it was outside but unfortunately, the strongest odor seemed to be around our back door.
Had to take off about ten deck boards before locating the thing. It wasn't right by the back door but about ten feet away. The prevailing breeze here (such as it is) blew the odor right at the back door.
The good news is once you locate and remove the carcass the smell departs rather quickly unless it has decomposed a great deal and liquified and soaked into any wood. If so you will have to replace that wood to eliminate the odor.
Leonard
La Vernia, TX
Wood Goods - Custom Woodwork
beeg
Post by beeg »
Toss a skunk into the back room.:D
beeg wrote:Toss a skunk into the back room.:D
Yep! THAT oughta cover it up!:rolleyes:
dan1999
Odour
Post by dan1999 »
If you got a dog let it out in that area, it may de drawn to the stink(they love dead things)and then get the dog away from the carcass once it finds it.
Or you can let a vulture into the shop they love to eat dead things.
Dan
Mark V 520,Mark V 510(2),Mark V 500(2) Dust Collector(2), Jointer(2), bandsaw(2), jigsaw, beltsander, biscuit joiner(2) Lathe Duplicator, RingMaster, Pro planer
tnerb
Post by tnerb »
dan1999 wrote:If you got a dog let it out in that area, it may de drawn to the stink(they love dead things)and then get the dog away from the carcass once it finds it.
Dan
Yup! A Vulture would do it....... Ya can rent em from your local 'Rent A Vulture') store!
mickyd
Post by mickyd »
Vicks Vapo-Rub on your nostrils for the next 3 weeks.
Sunny San Diego
mickyd wrote:Vicks Vapo-Rub on your nostrils for the next 3 weeks.
How about that! A dead animal made Mike come out of hiding!:D
Been pretty quiet this week! Hope you are busy, NOT feeling poorly!:)
