When ripping my Mark V seems to be underpowered
fwaterer
Post by fwaterer »
I am a new user of an older model Mark V. I love everything about it, but when I am ripping 2" lumber, it seems to be underpowered. I have replaced the main drive belt and am using a new thin kerf blade but even so, when ripping a cedar 2x4, and using what I think to be a very slow feed, I still have to stop regularly to allow it to come back up to speed. Is this typical or am I doing something wrong?
Thanks for the help from some of you who have "been there, done that".
I have it set or "R" with on the dial reads "Saw-joint". The wood was dry.
It is a Mark V - color is gray.
I am using a 5/8" arbor with a Frued blade.
beeg
Post by beeg »
What speed are you using? Is the cedar wet?
fwaterer wrote:I am a new user of an older model Mark V. I love everything about it, but when I am ripping 2" lumber, it seems to be underpowered. I have replaced the main drive belt and am using a new thin kerf blade but even so, when ripping a cedar 2x4, and using what I think to be a very slow feed, I still have to stop regularly to allow it to come back up to speed. Is this typical or am I doing something wrong?
Also 'older' as in What color? Is it a Mark V or a Mark 5?
enyoc
Post by enyoc »
My SS also bogged down ripping 2X lumber a couple weekends ago - I figured it was a dull blade, and since I don't have a 5/8" arbor nor spare blades, I ended up ripping on my RAS which is just plain scary!
Ripping soft wood is hard work for a saw, but I was still surprised at the bogging. It will be interesting to see the responses and suggestions in this thread.
Meantime, I'm ordering a 5/8" chuck so I can buy a blade when I need one without worrying about shipping/backorder time...
JC
Hampden Twp, PA
Bought, restored and sold a 520 before I knew what I had (and should have kept) - Now I found religion and I'm working on restoring a 500 and a 10E.
mickyd
Post by mickyd »
There's a ton of threads discussing ripping with ShopSmiths. Just search for the term and you'll be able to glean what the gurus have said in the past. There's a lot of good reading on it.
https://forum.shopsmith.com/viewtopic.php?t=3170&highlight=ripping
https://forum.shopsmith.com/viewtopic.php?t=3254&highlight=ripping
Sunny San Diego
shydragon
Post by shydragon »
I was having the same problem until I looked at the speed chart. For heavy ripping, the chart recommended a slower speed, in the case of the 510, setting of "O". After making that setting, all the problems went away.
Pat
Oregon
1992 SS 510, 11" Bandsaw on power station, 4" jointer, Pro Planer, Incra Miter 2000, Incra Ultimate Fence Router Pkg, Grizzly 6" Parallelogram Jointer.
tnerb
Post by tnerb »
I agree with Shydragon. I had a bogging problem when ripping also. Since turning the speed to the "P" setting, I haven't had any more bogging when ripping. I do all my sawing at that setting now.
Brent
wgander
ripping
Post by wgander »
In addition to using the right speed, be sure to use the riving knife if there's one for your saw to keep the kerf open.
Wet wood, twisted wood and knotty wood is difficult to rip.
tryinhard
Post by tryinhard »
When did it switch from being a Mark V to Mark 5? When the 510 was introduced?
beeg
Post by beeg »
Actually it went from a Mark 5 to a Mark V.
