Drum Sander
jonesuh
Drum Sander
Post by jonesuh »
i have the drum sander attachment for my 520----i have since accquired a drill press & a lot of times it's easier to use that the SS---has anybody figured a way to attach the SS drom to a conventional drill press or do i just have to but another drum for the press
jonesuh wrote:i have the drum sander attachment for my 520----i have since accquired a drill press & a lot of times it's easier to use that the SS---has anybody figured a way to attach the SS drom to a conventional drill press or do i just have to but another drum for the press
All you would need to do is adapt from the drill press chuck/shaft to the drum sander 5/8" bore. The shorter the better, as runout may become a problem.
RobertTaylor
Post by RobertTaylor »
if your drill press chuck has a #2 MT you could remove the chuck from the drill press and use a SS tailstock chuck adapter then add the drum sander. works for me.
