New to forum
New to forum
Hello Everyone,
I am new to this forum and to woodworking. I would like to come right out and ask: Is this Shopsmith tool as good as it appears??? I am setting up a shop in my basement and have limited space(12FTx15FT x 7Ft ceiling height) and it seems as if this would work out great for me rather that individual tools. Any input would be great.
Thanks, Carl.
Thanks, Carl.
- a1gutterman
Hi Carl,carlr wrote:Hello Everyone,
Thanks, Carl.
Asking that question on this forum will only get you one answer!!
If you have knot done so already, it wood be to your benefit to view each of the Sawdust Sessionsthat Nick Engler and associates have filmed. These will give you a good idea of the possibilities, maintenance procedures and solutions to problems that you may run across, with a ShopSmith..
Tim
paulmcohen
I my opinion it is the best tool for someone with limited space that wants to have most or all the tool functions the Shopsmith is able to perform.
I have a one car garage dedicate to my shop, if I tried to put in a table saw with as much table surface as my 520 I would not be able to fit anything else in my shop.
A well aligned machine is able to do anything a dedicated machine can do and some things they can't, ever see a variable speed table saw?. I have never seen a horizontal boring machine (for example) which function I use all the time.
Paul Cohen
Beaverton, OR
Beaverton, OR
paulmcohen
carlr wrote:Thanks Tim,
One of my concerns is the overall height of the unit when it is in the drill press position. I only have a little over 7FT ceiling height. Can you tell me this?
If I have the room I think I will go for it. It has to be better than the Skil saw I use now....
Thanks, Carl
Before I moved into my current home, I kept my Shopsmith in a basement with less than 7' ceiling and did not have an issue but it has been 20 years. I am in the middle of a project, not using the drill press or I would go out and measure it.
Paul Cohen
Beaverton, OR
Beaverton, OR
Thanks Paul, I'm looking forward to getting this tool.paulmcohen wrote:I my opinion it is the best tool for someone with limited space that wants to have most or all the tool functions the Shopsmith is able to perform.
Thanks, Carl
I can't put mine in vertical right now. But I measured my ceiling height and it's right at 7 ft. No PROBLEM.
