wood boring?
wood boring?
I am having some difficulty with wood boring. I have bored on a lathe and it comes out straight, what I am finding is that when I bore in the lathe position the bore begins in the center and then ends up offcenter. Does anyone have any suggestion?
tommyc wrote:I am having some difficulty with wood boring. I have bored on a lathe and it comes out straight, what I am finding is that when I bore in the lathe position the bore begins in the center and then ends up offcenter. Does anyone have any suggestion?
Exactly what are you boring? Turned workpiece, Square sawn workpiece, What size, End grain, Spindle shaped, Bowl shaped, Size bore???????
by "boring in the lathe position" do you mean that you have something mounted to the headstock spindle and are boring with the bit mounted to the tailstock?tommyc wrote:...when I bore in the lathe position the bore begins in the center and then ends up offcenter. Does anyone have any suggestion?
if so, there have been several discussions here about the proper way to mount the tailstock so that any flex is minimized.
a description or picture of your setup would help narrow down the best suggestions.
ER10 awaiting restoration
