Newbie Miter Saw Question
whereeaglesdare
Post by whereeaglesdare »
Hey guys, new here but I have a question. I have a 10" Compound Miter Saw and I need to make a beveled cut on a 20" piece of particle board. The saw fences only allow cuts of 6" at a time.
Any tips or tricks on how I can do this? Thanks.
knottymind
Post by knottymind »
Sounds like the wrong tool for the job. Plus that's sacreligious to use a good tool on particleboard....ugh! Good luck, however.
Steve
whereeaglesdare
knottymind wrote:Sounds like the wrong tool for the job. Plus that's sacreligious to use a good tool on particleboard....ugh! Good luck, however.
Steve
No suggestions?
I'm in complete agreement with Steve, but if you insist - Cut the bevel on 4 or 5, 6" pieces and put them together with half laps. The number of pieces needed will depend on the length of the half laps.
jb41339
Post by jb41339 »
In complete agreement with Steve. Wrong tool for job. Do you have a hand saw?
Jim in Tucson, AZ
burkhome
Post by burkhome »
whereeaglesdare wrote:Hey guys, new here but I have a question. I have a 10" Compound Miter Saw and I need to make a beveled cut on a 20" piece of particle board. The saw fences only allow cuts of 6" at a time.
Any particular reason you wouldn't use the table saw?
Roger, Waupun Wisconsin
ss50th
Post by ss50th »
Although I don't have excellent skills with woodworking I have dabbled some in mathematics. I believe what you're attempting with that miter saw is impossible. There's no way of getting around having about 8" of uncut wood in the center of the board.
Mixed feelings is watching your mother in law driving off a cliff in your new Rolls Royce. :) :(
Richard
bhurley
Post by bhurley »
I firmly believe that the first power tool anyone should buy is an electric drill - followed by a quality table saw. The second tool would serve your purpose.
Chin Up!
Got most all of them
bhurley wrote:I firmly believe that the first power tool anyone should buy is an electric drill - followed by a quality table saw. The second tool would serve your purpose.
Or Brace and bit(s) and a 'hand saw'. Then you will gain appreciation for what rural electrification did for the 'hinterlands'.;)
I believe that a home owner, even one who does very little wood work, needs to have the electric drill and a small circular saw. With these two power tools one can do a lot of construction. I carry these in my RV; it is surprising just how often they are used for repairs. It is also surprising how many picnic tables you end up building.
