Extension Table, Jointer
I have an upcoming project that will necessitate I joint a large number of long pieces. I taught it would be good to have a bit more outfeed support than my jointer provides.
[ATTACH]11475[/ATTACH]
[ATTACH]11476[/ATTACH]
Now I am ready.
P1150004 (Medium).JPG (74.19 KiB) Viewed 4981 times
P1150005 (Medium).JPG (76.23 KiB) Viewed 5166 times
Interesting attachment method to the outfeed table. Since my older jointer does not have the 'lip' the later ones have I had not determined how to do so.
Thank You for 'doing it for me'.
Excellent 'improv'!
Whatcha gonna make?
robinson46176
Post by robinson46176 »
Looks like a good effective common sense approach to me...
Of course you are not ready yet. You will still need a drive coupling. :D :D :D
8iowa
Post by 8iowa »
Dusty:
Back in '08, at the Shopsmith week-end in Dayton, I saw a jointer outfeed table extension designed and built by Nick Engler. I made a sketch and measurements, and even tho Nick said that it would be OK for me to build one for my own use only, I was not comfortable with that so I destroyed the sketch. Nick also said that Shopsmith was considering this extension.
Since then, many times I have successfully jointed and glued boards as long as 104 inches. I purchased Rockler's Heavy-Duty "flip top" roller stand. Placing this stand about 3 ft beyond the outfeed table, I adjust the height perfectly level with the outfeed table using a Veritas 50" aluminum straightedge. I also place another roller stand about 3 ft in front of the infeed side, and also level it with the infeed, again using the straightedge. It actually doesn't take a great deal of time to affect this set-up, and it really works.
Taking a tip that I gleaned from a woodworking video, for long boards I clamp the newly jointed board in my workbench, edge up, and taking a #5 hand plane set to remove extremely thin shavings, I hand plane the edge so that it is slightly concave. Thus when the boards are glued & clamped there is a small amount of "spring" making the ends very tight so that they will not split apart over time.
moose
Post by moose »
Thanks you for the post Dusy. This is an excellent idea and I will certainly use this myself on long pieces. I appreciate you sharing.
mgdesigns
Post by mgdesigns »
He has one on the accessory shelf.
Hand Engraver of Metals; Maker of Exquisite Kindling; 1955 Greenie Mark V (NOW with a 1989 Headstock); Magna Band Saw; Magna 4" Jointer; Miscellaneous Craftsman & Porter-Cable electric woodworking tools.
3D CADCAM Designs - Gemstone Facetor
dlbristol
Post by dlbristol »
Nice solution! I was wondering how to use my SS based outfeed table on the jointer, now I know! Thanks!
Dave
