Brand New Mark 5 owner
pnkfld98
Post by pnkfld98 »
It's a 1987 model 510 I got at an estate sale. Appears to have been lovingly maintained.
My question is about about a jointer that i have the opportunity to purchase. They list the model number as # 505681-B , serial # SS93177 but I can't seem to confirm if this would fit my '87 SS.
I looked here:
http://www.shopsmith.com/ownersite/itemnumbersearch.htm
and here:
http://www.shopsmith.com/ownersite/serialnumber.htm
and here:
http://www.shopsmith.com/ownersite/faq/jointer.htm
...but no joy. Is there an easy way to know if this jointer is compatible? :confused: Also, I'm not sure how it mounts, do I need mounting tubes or does it just slide onto the "head stock support"?
BTW,
I just wanted to add that i've been reading (and learning) a lot on this forums and wanted to let know that this site and it's users are top notch!
Thanks in advance.
pnk
Looking at the info in your last link, I would conclude that yours was manufactured in Jan/Feb 1986.
[ATTACH]11671[/ATTACH]
Please_ Please_ Please edit your profile with a name and location. We can better support you that way. It also makes for a friendlier forum. We are friends, Right?
Please, Your Profile.gif (7.13 KiB) Viewed 1566 times
nuhobby
Post by nuhobby »
I have put a 1958 jointer on a 2007 Mark V, and vice versa -- I think you'll be fine....
For maximum mounting flexibility, the stubby eccentric posts are good to have. See item #61:
http://www.shopsmith.com/ownersite/part ... xpview.htm.
If the jointer just has straight-pipe posts, then it's not as easy to line up with the Mark V jointer shaft. It can be done with some frame fiddling, but the eccentric posts are the easier way to go.
Chris
All versions(colors) of the jointer model 620 will fit any Mark 5 or Mark V or Mark VII or Mark 7.
The older model 4(rarely seen) only fits the 10E/ER with a special headrest.
It mounts on tubes that slide into the SPT mounts on the end castings. The older mounting tubes are straight, but later ones have an offset.
The reason for 'no joy' was "it does fit all"(almost).:)
P.S. Some recommended 'reading'! http://www.shopsmith.net/forums/showthr ... t=newowner
pnkfld98
You guys are awesome.
Post by pnkfld98 »
Dusty,
Appreciate the post and mia culpa :o, I have updated my profile. Best part of this hobby is making friends IMHO.
Feeling quite privileged to be part of this very cool place.
Nuhobby,
excellent illustration. Thank you!
JPG,
Thanks for the elaboration and link!
