I am really going through my greenie 1957 SS and repairing/replacing as needed. The motor is the GE 3/4 h.p. with the capacitor and starting relay. The starter relay appears to be starting the motor fine, but has a slight vibration causing it to "buzz" at the metal pivot points when the motor is running. The contact pionts are clean and the coil seems fine, just some wear on the internal metal housing where it pivots. If I move the metal pivot over a 1/32", then the buzzing stops.
My question is this: Can a "universal" type relay be used if this one craps out (from Grainger or McMaster-Carr)- what would I be looking for specifications wise? One post shows a MARS 550 Potential Relay as a replacement, but is this the only one that will work? I am not picky about mounting the relay in the original location on the motor. Thanks for all the help thus far. Chris in GA.
Replacement Starter Relay for GE 3/4 H.P.
justplaingoofy
- Silver Member
Can you post a good close up of that relay you are referring to please?
"Don't Be So Open Minded That Your Brains Fall Out"
1959 SS Mark V w/all attachments; 2 Craftsman 100 Table Saws; Delta 40-A Multiplex RAS; 6" Jet Jointer; Delta HomeCraft Floor and Bench Drill Presses; Dremel Everything; Rigid Dust Collector; and a vast collection of hand tools.
Additional relay info
My digital camera is broken, but it looks exactly like this one (see link below):
https://forum.shopsmith.com/viewtopic.php?t=3227&highlight=3arr1
On the case the relay is marked: "3ARR1 AE73" and made in 1956.
gunner66 wrote:I am really going through my greenie 1957 SS and repairing/replacing as needed. The motor is the GE 3/4 h.p. with the capacitor and starting relay. The starter relay appears to be starting the motor fine, but has a slight vibration causing it to "buzz" at the metal pivot points when the motor is running. The contact pionts are clean and the coil seems fine, just some wear on the internal metal housing where it pivots. If I move the metal pivot over a 1/32", then the buzzing stops.
Start relays are voltage sensitive and calibrated to pick/drop at specific voltage ranges.
The ge relay is speced to pick at 111 to 134 v and is rated at 130v. It stays picked until the voltage drops below 40v.
A universal relay is not calibrated as such, but will probably work(sorta). You need to be sure it picks reliably at startup, stays picked under all load conditions(including temperature) and does not drop out too soon at power down.
The mars550 is yer best bet considering it is the same mount etc.
Thanks JPG,
I looked up the part and Motors & Armatures, Inc. (MARS) still/currently manufactures the MARS 550 GE Potential Relay (P/N: 19550). The specifications were exactly as you indicated. I filed this info away if I ever need to replace mine. Thanks again
for explaining and providing the relay's specs.
The company's website is: marsm-a.com
They match the original GE spec for that 'model'.gunner66 wrote:Thanks JPG,
I looked up the part and Motors & Armatures, Inc. (MARS) still/currently manufactures the MARS 550 GE Potential Relay (P/N: 19550). The specifications were exactly as you indicated. I filed this info away if I ever need to replace mine. Thanks againfor explaining and providing the relay's specs.
