I Must Be Crazy
Gene Howe
I Must Be Crazy
Post by Gene Howe »
Today, I'm picking up a treadmill to convert into a HUGE (14 1/2 X 48) unstoppable belt sander. The motors are DC and we all know about their unique qualities, don't we?
I'm getting it from a lady who bought it 3 years ago and then moved to a home "off grid".
Stay tuned.
Gene
SDSSmith
Post by SDSSmith »
Old treadmills are very popular in the Shopsmith 10ER community, you lucky dog.:)
Rob in San Diego
pennview
Post by pennview »
I picked up a couple of older Sears treadmills a while back thinking I scored two DC motors and controllers for $10 each, but one came with an AC motor. The way to recognize the difference I learned was in the mechanism that varies the treadmill speed. The DC one used a dial and rheostat, while the AC model used a mechanical crank mechanism and long speedometer-like cable to vary a set of Reeves-type plastic pulleys to adjust the speed. Some of the DC motors are also controlled by a touch pad or slider. The moral being, one shouldn't assume that all treadmills use DC motors.
Art in Western Pennsylvania
Where ya gonna get the sanding belts?
Doubt quick changing will be a 'feature'.
Gene Howe
Post by Gene Howe »
Well, I got it. It's DC, has tensioning springs and an alignment lever (I think).
Still in the back of the truck but I measured the roller width at 16 1/2" and the belt is probably 48". The whole unit is 60" long. I gotta get the head off to get an accurate measurement.
The plate it's running on is that phenolic covered 3/4 ply. If it's still flat, I may use it.
Added bonus: I can check the wood's pulse rate and blood pressure.:D
JPG, Here's where I get most of my belts. They have the lengths I'll need.
Wide belts
Gene
crokseti
Post by crokseti »
Funny I had that idea many years ago. Now everyone has one.
If I ever set up a full shop I will convert one to sand large pieces.
spiderclimber
Post by spiderclimber »
I figured you would just go out and get the sticky sanding pads for a hand sander and start sticking them to the belt. A hundred or so later you would have a sanding belt :D
Gene Howe
Post by Gene Howe »
spiderclimber wrote:I figured you would just go out and get the sticky sanding pads for a hand sander and start sticking them to the belt. A hundred or so later you would have a sanding belt :D
You got it. That's my plan. Except I intend to use Velcro. That way I can Have two or three different grits available. :D
Gene
Gene Howe wrote:You got it. That's my plan. Except I intend to use Velcro. That way I can Have two or three different grits available. :D
Or different grits across the width.:D
Gene Howe
Post by Gene Howe »
Well, Wife and I unloaded the treadmill from the truck and wheeled it into the shop.
As soon as I finish up the mirrors and get them sent off, I'll be tearing it down to the essentials and building a stand. I have around 80' of 2X4 steel tube that will make a nice stand.
I'll post beginning pics as soon as I get it all torn down.
And, after reflection, I decided against using the Velcro, multi-sheet system.:D
I found a supplier that will make up any belt size I need. Estimated cost was around $30.00 delivered.:)
Gene
