http://www.shopsmith.com/ownersite/specials/7DU137.htm?jn=29258&kt=MKT&kr=0007385781&cnum=0007385781&epn=RWWUYSR
Link no longer valid!
This should be 'permanent'. http://www.shopsmith.com/ownersite/cata ... asters.htm
ryanbp01 wrote:Why do the legs have to have new holes drilled? I would assume it is to accomodate the wheel diameter?
BPR
Don't think that will happen. You have to be able to lower it to get it on the ground, and raise it to move it, all that will remain the same. The difference is that a new set of holes moves everything up to account for the new caster height.jayp413 wrote:I like the idea! The price is not bad either. A little more ground clearance so you do not catch on uneven surfaces would be a welcome change.
