Miter Gage Extension plans
I went looking for the dimensions to make an extension for my Miter Gage and didn't find one. So I found it in the online PTWFE and here it is. I made mine 4.5" tall.
[ATTACH]14324[/ATTACH]
[ATTACH]14325[/ATTACH]
Miter Gage Extension.doc- (57 KiB) Downloaded 317 times
- F2-21SM.jpg (11.43 KiB) Viewed 1768 times
The reason for the original height was to allow flipping it for use on either side. The mounting holes are centered.
Higher would be better for larger workpieces.
paulmcohen
beeg wrote:I went looking for the dimensions to make an extension for my Miter Gage and didn't find one. So I found it in the online PTWFE and here it is. I made mine 4.5" tall.
If you make it double hight, you should add two sets of holes so it can be used on both sides.
Paul Cohen
Beaverton, OR
Beaverton, OR
Or set of holes on both ends!:)paulmcohen wrote:If you make it double hight, you should add two sets of holes so it can be used on both sides.
Miter Extension
Keep on the look out for an Incra fence. It works perfectly and is adjustable from one side to the other. Can be equipped with a stop.
MarkFive510
swampgator
WHY ya have to remove the hold down?swampgator wrote:Use mine frequently, especially when I want to rip small pieces. It's a great fence, but you have to remember to remove the clamp from the top.
I found out AFTER using mine, that I should have made it a little narrower.
swampgator
The board is too tall. But, is very handy to saw short logs. Have some dogwood to cut soon with a diameter of 6" - 8" and my fence is very helpful with such activity.beeg wrote:WHY ya have to remove the hold down?
Steve, the old Florida gator
I just love it when she says I can go make sawdust.
