stop collar indicator tape
fredw
Post by fredw »
Can someone tell me exactly where to find the stop collar indicator tape PDF.
Fredw
fred
Try this: http://www.shopsmithacademy.com/Tips_Ar ... _tapes.htm
Once you get there, you'll see the blackboard. Follow the instructions on the blackboard and you'll have it.
fredw
Srop collar
Post by fredw »
Thanks Dusty
Fred:)
fred, you may have to fiddle around with your printer settings to get this to work out correctly. Even then, you probably won't get it exact. It appears that our printers do not all handle graphics with the same degree of accuracy.
If you get a tape that is just a tiny bit over 7" long you'll have it as close as I was able to get it. I tried on three different printers with nearly the same results.
Good luck. I believe you'll find the stop collar to be a very worthwhile addition to your Shopsmith.:)
