Since I've got to get out by April (reportedly) I called the painter back so he could crank out top coating the V-berth with ICA catalyzed clear in satin. While he was sanding, I was making the last solid mahogany pieces (door jamb etc). The Boatamalan painter laid on four more coats of base, for a total of eight (four were sprayed in the tatami spray booth before I installed the panels). Then he sanded again and sprayed the top coat. It looked great the next day, when I arrived to pull the plastic!
And then I saw it in a photo I took. It was all white. Then I touched it, and it felt like 120 grit. The last part he sprayed is perfectly smooth, but the overspray from that didn't melt in to the top coat around the rest of the room.
The whole thing's oversprayed and has to be sanded and sprayed again.
I'm starting to like the idea of rolling and tipping more and more. Unfortunately, I already bought all of the ICA, and it doesn't roll and tip well.
1969 Chris Craft Roamer 46 Refit: Top Coating the V-berth
Cheers,
Q
