One of my priority items is to confirm that the engines will light off when the boat gets splashed. I thought I was ready to start them, but neither passed the test.
On the starboard side, the injector pump lost prime because of a crack in the OEM fuel return line on the pump body. That was allowing fuel to leak out and air to leak in. And the steel line is in an awful place. To replace it requires R&Ring the injector pump...
The port side lit off almost immediately, but then died when I released the key. That happened a few times, and I discovered the key switch is shot. It doesn't send power to the RUN circuit, which energizes the locking RUN solenoid on the injector pump. Additionally, there was a bad battery connection (entirely my fault) that ended up blowing the main fuse.
So...the good news is both engines clearly are willing to start, so long as they get fuel and electricity where they need it. I've already fixed the battery connection problem, and the new key switches are ready to be picked up. The bad news is that fixing the fuel system is going to be a big project.
You can see the tests in the video at the linked blog article.
1969 Chris Craft Roamer 46 Refit: First Try Starting My Cummins Main Engines
Cheers,
Q
