alxlo1 wrote
Take the belt guard and pan off, put the machine in drill press position, remove the 4 lower motor screws, (loosen the top 2 screws, but don't remove them). Tilt the motor out which exposes the screws holding the black plastic shroud, remove the shroud, (3 screws). Use a can of compressed air to blow out the sawdust, particularly around the speed sensors, put it all back together and it should work fine, (it did for me). Total time was about 30 minutes. Don't know why SS doesn't list this as a troubleshooting solution.
THANK YOU! I got the RPS State Error code, and followed your instructions. It started up and ran. I have not yet put it under load, but that will be coming soon. I went as far as removing the fan and actually ran a soft cloth over the sensors, and then used compressed air on them. I hope this fix lasts for a while. Thank you, again.
