The kreg jig requires a special bit to make the pockets. It is basically a stepped bit that looks like this:
[attachment=6]$matches[2][/attachment]
When we talk about setting the collar depth stop it is from the collar to the step of the bit as shown with the green measurement. The point is not in the measurement.
In this picture note how the pilot part of the bit corresponds to the screws un-threaded portion.
[attachment=5]$matches[2][/attachment]
As an aide in setting the depth kreg has various helpers. On this jig they have a depth gauge built in. Not really easy to see in the photo but not so bad on the tool.
[attachment=4]$matches[2][/attachment]
This is only an example so what you have many or many not look like this.
To set the depth you first need to know the actual thickness of the material. Then you loosen the collar and put the bit in the jig, set the depth and tighten the collar. Here is the bit set for 3/4" material:
[attachment=3]$matches[2][/attachment]
A little heads up, 3/4" plywood is less then 3/4" so you can fudge the collar placement towards a lower number, but don't get too carried away and doing a test before hand is a good idea before jumping in and doing damage because you were a bit too far off.
This brings us to the the main part of the jig. There are metal guide bushings to guide the bit and keep in on course. Again kreg makes a few of these so this is just one example. In this picture you can see the portion of the jig that is against the material when drilling.
[attachment=2]$matches[2][/attachment]
This is what the bit looks like when set to 3/4" material and inserted in the jig all the way. Also note the markings on the side of the jig.
[attachment=1]$matches[2][/attachment]
Those numbers are used to locate the jig into the mounting system as seen here:
At this point we have our bit and jig set to drill pocket holes in 3/4" material.
There have been quite a number of different jigs along the way and what I have been showing is the K4. I have the K3 and a couple of older ones including the very first one I got many many years ago. They have now progressed to several newer models which I have had no exposure to.
Next we will talk a bit about some simple joints and other topics.
