Kenny,
First off welcome to the Forum.
Sorry I do not know which Jacobs Chuck the #36 is. Jacobs Chucks generally attach one of two ways. Either by threads or a tapered friction fit. The #36 is likely one of those two ways of attaching the Chuck. To use on your Shopsmith Model 10ER it would require an adapter. Most commonly the Drill Chuck is attached to the Shopsmith's 5/8" reverse tapered spindle but some uses have it on the Tailstock using a #2 Morse taper adapter. Having been 70 years plus or minus three years since the Model 10's were made other non Shopsmith parts get mixed in.
The Jacob 33B was the original chuck used for the Shopsmith Model 10E and had an adapter to attach it to the spindle. See the one in the picture below on the lower left. It was soon replaced by the Jacobs 3326 Chuck with a smooth 5/8" bore and a 3/8" set screw. It was made by Jacobs for the Shopsmith tool. That is the one that originally came with your 10ER. The picture below is of the different 1/2" chucks used for the Shopsmith tools over the years starting at the lower left. It does not include the 5/8" Keyless Drill Chuck currently sold by Shopsmith. The part numbers are from the Shopsmith parts lists not the Jacobs or other manufacturers numbers. There are other part numbers associated with these chucks found in Owner's Manuals, Parts Lists or Catalogs. Some are for individual parts but the ones listed in the picture below are for the complete Drill Chuck Assembly.
In the picture above from the lower left to right is the Jacobs #33B on an adapter, the 3 versions of the Jacobs 3326 Chuck (differing set screws) and the Cushman Chuck. The top row from left to right is the 2 Jacobs Multi-craft Chucks (labeling) and the 3 versions (labeling) of the current Shopsmith Chuck.
Drill Chucks aside you may find the forum post below interesting if you have not already read it.
https://www.shopsmith.com/ss_forum/community-f7/shopsmith-model-10-s-what-when-and-where-t23647.html
