BigSky wrote...The only time your Mark will draw more current than that is for a very brief moment at startup... Also, I suspect that the current on/off switch in your Mark is rated at only 15amp.
Motor Rated switches are intended and rated for applications like this (AC Induction motor) with high short term current demands. Personal view here - if I replace a SS power switch I'm using a motor rated switch that's rated at a minimum of 1-1/8 HP. Those tend to be rated at 20 Amps. A leftover toggle version from my PP DIY kit (they provide both types) is rated at 1-1/2HP at 125 - 250 VAC, 20 A at 125 VAC, 10A at 277 VAC. I suspect this is what you'd get if you ordered a new replacement switch from SS.
Sellers may not always provide the motor rating even if the switch has one, but my presumption in the absence of a HP rating, as in this case, is that the switch is not motor rated. Motor rated slap switches are readily available but I don't know about finding one that is pre-wired. Another option might be to relocate the toggle switch (or add one) with a safety cover.
