reible wrote
So ZCI doesn't need to be an issue. The best way to deal with this is to lower the table over the blade with the blade locked in position. You can then adjust the quill to get a centered location in the insert if needed. You can hand spin the blade from the none blade side and get just about a perfect fit this way. I have also found that a small amount of extra width doesn't effect the cut much or does it cause me to want to replace the insert for most work.
Thanks Ed. Yeah, this is exactly what I do every time. I slowly lower the table and try to adjust the carriage left/right to get the ZCI to slide around the sawblade. Also, I am using the same Forrest blade every time. Most of the time I am making a cut with just the main table alone, so perhaps the "play" the main table has causes the ZCI opening to grow wider and wider over time. I would have to try with a fresh ZCI and always use connector rods between the main table and aux table to see if by stiffening up the main table if I can prevent some of this "slop" that invariably creeps in to my cuts. Another alternative is I could rely on the rubber bumper alone and see how much it moves each time. When I attempted this before though I noticed that I could not always lower the sawblade into the same ZCI slot, i.e. it would hit on one side.
Thanks for the suggestions.
