This is my video demonstrating the Proteus power feed. You can see more videos on my youtube channel at
https://www.youtube.com/channel/UCp7QgDE6eTU8FOmVRCbPrTw
I am in the process of evaluating Al Ladd's "Little Proteus" power feeder. I don't want to get into a full review until I have time and other projects aren't getting in the way, but I wanted to mention a couple of things.
You will want a non-thru-cut riving knife to use the feeder properly - the taller standard knife tends to get in the way.
If you angle the Proteus, it will help keep the work against the feed, as the wheels will push it in. You may want to add featherboards to ensure there is no movement, however, unless the Proteus is locked down tight, because if it's not tight, there is the possibility of movement of the board. I noticed no fence deflection even when applying downwards pressure on the Proteus with the screw handle; the wooden frame of the Proteus allows it to twist somewhat, which in this case is probably a good thing...
The Proteus works well and certainly fed the wood through at a decent rate of speed. A LOT of that will be dependent on the tool you are using to power the Proteus. My Ridgid main battery drill gave me too high a feed rate; my big Ridgid corded drill had a nice feed rate, but it's just to big and cumbersome. The right angle tool worked GREAT but my right angle tool is a 3/8 chuck, so I had to actually turn down the output shaft on the Proteus to get it to fit (it's 1/2 inch) on my Sherline microlathe. Al Ladd says he's going to switch to a 3/8 output shaft so you will have a wider range of tools to power it with.
I think the Proteus offers some nice features (lower cost, relatively small size, fence mount, flexibility).
I think the main disadvantage for Shopsmith users will be for those who do not have some form of ripscale measurement on their fence system. I made my own; Shopsmith sells a ripscale accessory (magnetic rulers you mount on a 520); but without a ripscale, it's not easy to measure from fence to blade with the Proteus straddling the blade. In my case, I just set my rules up and align before adding the Proteus; then it's a simple matter of just using the cursor on the fence base to measure the scale on the table rail.
So far, I like it. A full review will be coming in the next few weeks, once I have time to set it up on my Shopsmith based routing system; and I want to set it up to work on my Shopsmith mounted 19" drum sander, as well.
More to come!
