chapmanruss wrote
...I don't recall any problem with the length of either the bench or way tubes not seating completely into the base and arms of the double tilt upgrade when I added it to my 2001 Mark V 520 a few years ago. Both of the bench tubes are seated against the stops on each end in the bases. I don't want to take apart the way tubes and arm parts but I believe they are fully seated too, IIRC...
Not a problem, just the way it is, but this is from the DT Installation manual:
"Center the Way Tubes in the Pivot Arms. You probably noticed that you will be able to slide the Way Tubes Left-to-right about 3/8”. Follow the steps
below to center the Way Tubes:" (
https://www.shopsmith.com/ownersite/manuals/845633_C_04-12.pdf) Page 10 starting at step 5.
That is how my machine that is upgraded to Mark 7 is, way tubes are centered, not seated. When I put DT on my shorty I needed to cut new bench tubes anyway (cuz it was a Greenie with large diameter tubes) so I cut them shorter to enable the way tubes to seat.
