Hobbyman2
Years back we used fast blowing fuses in all 220-240 HVAC circuits , to my knowledge there were no 220 v GFI receptacles , there should be a fused disconnect / some had breakers / before each point of use . to my knowledge each point of use was dedicated with a direct feed to the panel , ,,,,,, Does 240 volt outlet in garage need to be GFCI?
For example, GFCI protection is not required for single-phase or three-phase, 240-volt, 30- or 50-ampere receptacles, or similar. During the 2020 NEC code cycle it was substantiated that unintended tripping of GFCI protective devices often creates significant safety issues.
2020 National Electrical Code frequently asked questionshttps://www.dli.mn.gov › default › files › pdf › NECFAQ20
