lahola1 wrote
1. If you use the controller that came with the treadmill motor (mc60, mc2100), you should have no problems controlling the motor.
2. Basically you throw out the 1st and last 15% of the control band as unusable; low power or low torque.
The mc2100 board needs a PWM signal of 20hz. I replaced the big treadmill control panel with the a small PWM signal generator (amazon approx $12).
Excellent info in your links, I'll have some questions for you in a while.
In reference to the MC60 controller, have you heard of any use of PWM with this board? Here's some info of unknown origin hinting at that possibility. Note the comments on D7, the LED labeled SPD CTRL:
"These SCR motor controllers are physically identical. The only difference is in the components used to allow a
higher Current Limit on the MC-64 and a lower Current Limit on the MC-67. The MC-60M controller is a variation of the
MC-60 controller that allows a single wire harness to carry signals between the console and controller. The treadmill’s reed
switch plugs into the controller, then the tach signal from the reed switch and the speed control signal are sent to the console.
These controllers can be configured to operate at different speeds and with various consoles by clipping one or more
resistors on the controller. Configuring the controller is done at the factory and should not be attempted in the field.
Clipping a resistor changes the part number of the controller. Always be sure to order the controller configu red correctly
for the Model number treadmill you are working on by referencing the model number's part list.
A new feature of these controllers is four troubleshooting LEDs that can be used to troubleshoot the controller when
repairing a treadmill. They indicated when the controller is receiving the expected control signals and outputting the required
voltages. Each LED is displayed below:
D6- Labeled SCR. Indicates that the SCR is triggering on the controller. If this light is out, no voltage will be sent to the
motor. Note that this LED will vary in brightness, depending on the speed setting. If this LED does not light when the
safety key is inserted and D7 is lit (indicating a speed setting other than zero MPH), the controller will need to be
replaced.
D7- Labeled SPD CTRL. This LED indicates that the controller is receiving a speed signal from the console. Note that on
consoles without a power board that use a speed pot, the LED will light solidly, but vary in intensity at different speed
settings. On consoles that use a power board, the LED will flicker with the PWM control signal. The brightness of the
LED will vary with the speed setting. NOTE: On consoles with speed potentiometers that require a power board, this
light may be seen to flicker even when speed is set to zero MPH. This is due to a small signal being sent from the
console. MC-60 controllers with this console and power board configuration will have RPS 1 clipped to operate
normally and keep the treadmill from running at all times. If this LED is not lit when the speed is set above zero MPH,
but D11 is, it indicates a problem with the console, power board, or wire harness."
