dusty wrote
as you raise a fully configured Shopsmith from horizontal to vertical is there a point (60,70,80 degrees)where gravity steps in and assists that transition (ie: completes the rotation)?
Yes. On the center of gravity, when I tried this morning, at about 73° is where the center of gravity took over for my Mark V when raising to vertical causing it to tip over the rest of the way into fully vertical drill press mode. Of course, I had my main table extended (for drill press mode), so I am sure this angle is dependent on where the headstock is locked down as well as the carriage and main table positions. FYI...I don't have the double-tilt base.
