DLB wrote
dusty wrote
Please - if you see an error in my thinking say so. I would very much appreciate being shown the light.
Previous results, both measuring RPM and measuring minimum radius, suggest to me that there is an error in your modeling that suggests a 2.75" large radius corresponds with a 1.25" small radius. Since I don't know the logic that ties these together I can't guess. I consider the 2.75" to be correct for slow speed. My best estimate of minimum radius, measured at the datum line (also best estimate) is 0.916" for standard belt, fully closed Idler sheaves, proper eccentric adjustment, typical upper belt, etc. (sample of one, YMMV cuz this obviously vary a bit). So I think your error is in the small radius that corresponds with max radius: 1.25" Vs 0.916".
In an earlier post where I corrected my minimum radius value to 0.916", calculated RPM and measured RPM were within 1%. I'm pretty satisfied that this is an accurate number
for the one machine I measured it on.
If this is the machine with a belt that rides proud on the large pulley I may understand. According to my calculations with a 26.5" belt and a .916" radius small pulley the larger pulley needs to have a 2.9" radius. This produces an idler speed of 1080 rpm on one end and and 9357 rpm at the other end. That equates to 681 and 5847 rpm quill.
If you recalibrate to locate the belt on the large pulley to be 1/8"
below the perimeter the idler speeds change to 7602rpm and 1485 rpm with the quill running at 4751 rpm and 928 rpm.
With a slightly shorter belt (26 3/4") The speeds become 7674 rpm and 1516 rpm or 4786 rpm and 947 rpm and the quill.
Shopsmith chart: 1120 and 8400 or 700 and 5250.
I guess it can be said that I am running with the wrong belts - 27" purchased from Shopsmith.
I must say though that except for not hitting the right speeds at the extremes - the speed control system works great and since I hardly ever go toward the high end I am quite satisfied.
Through all of this, I have developed a couple cludge tools (depth gauges) for measuring pulley radius.
