chapmanruss wrote
The Wood Extension Table does look like it could be original based on the size in relationship to the Fence. In your pictures the Fence blocks seeing the mounting holes. I have some of the original Wood Extension Tables and they are not in good shape except one is in pretty good useable condition still. I have made several replacements. There were actually two versions of the Wood Extension Tables. The difference is the holes and how the wood is mounted to the bracket.
Thanks again Russ, i really appreciate all the info. I do think this table could be original, it is in great shape aside from discoloration from age so I don't think it has seen as much use as the rest of the tool.
I spent some time going through the large format drawings and other goodies on Everett's google drive. What a fantastic collection of goodies. I think I will make the accessory wall rack for my SS extras. I have a solid Delta Rockwell table saw, and a good drill press. My SS didn't come with the sanding disk but I have lots of sanders. The lathe and boring features are what I am really going to put to use, so I may build a tool tray for my in-use chisels and gouges to mount on the extension table. I am also considering replacing the allen screws on the tool rest with appropriate handle bolts to speed up adjustments. I am very happy with the quality and stability of the lathe, I will likely add voltage controlled variable speed, and a 4 sided chuck for turning bowls.
chapmanruss wrote
As for the color you paint your Shopsmith that is up to you. I am a traditionalist and paint my Model 10's Gray. I have seen pictures of ones painted other colors which are beautiful tools so make it your own and the color you like.
Pictures coming soon, those darn almost flat letters on the badge were a challenge, i think I have it cleaned up now. I figure if I am the one that has to look at it, then it should give me a smile. Another 75 years from now some other guy or gal can take it back to grey.
