joneill4 wroteIn a given decade, how many times will you guys pull the logo plate?
Over the past 43 years (4 + decades), it would be hard to say. To perform the recommended lubrication after every ten hours of use, I removed the access cover numerous times during the first few years when I used it the most. Besides for lubrication and cleaning purposes, if I have to remove the motor when the centrifugal switch inside of the motor needs cleaning, I'll use the access hole to remove the power switch to make motor removal easier. It takes several more minutes to remove the motor than just the access cover, and not something I would enjoy doing just to lubricate the sheaves and blow out some dust. After having the button bearing fail on me, I now probably lube more often than every 10 hours, and I would guess once every 4 months or so. I can't imagine not having the access hole, even if it is relatively small for my medium size hands.
