JPG40504 wroteWhy are they soaking in 'evaporust'? I do not see any rust in the pix. "Kerosene" would work better!
BTW Are you trying to move the floating sheave, or punch a hole in the plywood???:rolleyes:
I had soaked it for a few hours in paint thinner per the speed changer documentation which did nothing. If you look closely at the shaft between the
should-be-floating sheave and the right sheave, you'll see a combo of what appears to be red rust and a varnishy / shellacy material. Photo doesn't show it the best but I looked with higher magnification and I could see it. If Evaporust doesn't work, I am going to use 'karosyrup' since I can't find 'kerosene'. As you recall the gas station attendent directled me to it when I asked if they had 'kerosene'. :D Seriously, if Evaporust doesn't work, I'll just throw the thing away. (not). The beast has gotten me a tad frustrated over the past week of my vacation!!! No slam dunkers AT ALL.
Knowing the availability and the replacement cost of the speed changer, I opted to use the plywood backing block to minimize the 'maximuse forcous' that can be applied by the rotational transfer of energy on an inclined plane of a screw thread. :cool: In other words,
I was scared to death to break something!!! I had tried using a metal backing plate first but the instant the pullers center rod contacted it, it was like pushing on a solid. As you know, with a bearing puller, if something is going to move, it will usually show some sign when applying just a small amount of torque, again due to the mechanical advantage of the screw thread.
So, one more cup of java, read up on new forum posts, and I go to see how Evaporust bath did. If that doesn't work, maybe I should try 'Kroil'. :mad:
