I have two versions of carbide tipped combination blades with the SS logo, one NIB normal kerf and a newer but used thin kerf. My thin kerf has a flat tooth every fifth tooth and, of course, 1-1/4" arbor. But I cannot tell if this is the same thing they are selling now as it looks nothing like the picture in the on-line catalog. But the picture also does not look like a combination blade. Mine does look like the combination blade in this picture of a three-blade set: (
https://www.shopsmith.com/product-page/carbide-tipped-specialty-saw-blade-package-for-mark-7-mark-v-520-510-505). My best guess is that if you ordered a standard (which is now thin kerf) combination blade you'd get one like mine with a flat tooth every fifth tooth. Perhaps someone that has bought one more recently can confirm.(?) I like this blade and have nothing bad to say about it, though I initially didn't want a think kerf blade.
Note - the three blade set I linked was not previously called a specialty saw blade set. It appears to contain a Rip, Crosscut, and Combination blade, 1-1/4" arbors. 'Specialty' has previously referred to plywood, non-ferrous metals, and plastics, all with 5/8" arbors. The new web site is a work in progress.
I think you can also get the Woodworker with a 1-1/4" arbor if your order direct from Forrest. But I wouldn't really recommend this in your case. You said you are new to the machine as a TS. Some don't like it or even hate it. You'll be better off with the 5/8" arbor on an expensive blade if you find you dislike the SS in this role. I initially didn't like my machine as a TS, but later changed to a Model 520 and found it was much more to my liking.
