devoibew3 wroteI just purchased a Mark V 510 . Its an older model and the work surfaces on the saw table and extension tables have black spots. I've tried every cleaner I can think of but they dont come out. Any suggestions? Thanks for any help.
Black spots are probably stains from sweat. You wouldn't think I would know that living in Florida but I do. Of course we always tell the tourists it usually ain't this hot here, this is unusual. I love the weather on TV everyday is record setter. We have been setting records since 79 when I got here.
What I usually do is get one of those green fabric sanding pads, spray it with DW 40 and set it on my table with my 1/4 palm sander sitting on top. Let the sander do the work and wipe off the table real good and give it a good coat of Johnson paste wax. If I wax often enough and run the air conditioner only to keep the air circulating (wink wink) I don't have the problem. But if the wax gets worn off I will from time to time end up with a black spot or two. Only on the record setting days of course. :D
