Hello all, 1st time to the forum and first time Shop Smith owner.
I'm retired and have a 28' x 32' dedicated woodworking shop set up with just about every woodworking tool you can think of, Delta Uni-Saw, Shop Fox 14" Resaw Bandsaw & 8" Parallelogram jointer, 20" thickness planer, large drill press, router table, morticing machine, you name I got it. All taking too much space and too much maintenance.
I've done woodworking for over 40 years, everything from Homes, Timber framing, Multi-Family Apartment projects to custom cabinets & furniture and I've decided to downsize and in the process selling off the equipment.
I looked at Shop Smith many years ago before all this started and now have come full circle with the purchase of not 1 but 2 separate Mark V's that I think I got a good deal on.
(see photos)
The 1st Mark V is an older 500, that was converted to a shorty with jointer, Belt sander and is currently set up as a dedicated machine utilizing the Band saw and Jig saw attachments. It also included some accessories. It appears to be in good shape
The 2nd Mark V is a NEW old stock 510 with Pro fence system out of the box built in 2002 with Bandsaw, Jointer, Belt sander attachments, Shop Smith Vac/dust collection system and tons of accessories, i.e. Drill bits, router & shaper bits, sanding drums, three 12" sanding plates with a 1/2 doz. sandpaper discs packs, arbors, mandrels, saw blades, manuals and the list goes on and on, right down to a can of Shop Smith touch up spray paint. Absolutely nothing has ever been used and most are still in the original boxes & packaging.
I was told by the seller he had purchased everything from a widow whose husband recently died. He had secretly purchased it new 20 years ago, hiding it from his wife. It was never used and remained hidden until found by the wife and subsequently sold to my seller.
The only attachment I don't have is the 12" Planer, but have found a couple on Marketplace that I'm trying to make a deal on.
I purchased the everything for $1,200, so I think I got a good deal. I haven't even turned on either system, so hope it all works. The real challenge will be changing my mind set from having a dedicated piece of equipment to perform each woodworking task, to following a predetermined sequence of events that the Shop Smith system is best suited for. I look forward to the challenge and will be revisiting the forum for tips, tricks and useful ideas in the future.
Any advice and feedback is welcomed. Keep making the Sawdust!
