dustywoodworker wroteIs there more than one problem?
charlese: In your post on Tuesday you reported:
"My T-nuts will not fit the 510 rip fence - but will fit the bandsaw rip fence and the bandsaw table. Go figure!"
Are you having the same experience as dannos or do you have something different?
___________________
Making Sawdust Safely
I only have two T-nuts. They both came with my OPR. Both of these nuts when held in my hand (nothing attached (naked)) will not slide into the 510 rip fence. They will slide into the other places.
Yes, since my nuts won't slide into the 510 rip fence - I don't intend to use them there anyway. If I ever buy a rip fence feather attachment - if those nuts don't fit, I'll just file the nut's wings a little.
This is probably enough to say about these little nuts! The only reason I got in here is because of dannos problem. Since mine won't fit in the rip fence, I thought there might be a larger issue. Wow! this has been a lot of words over one problem that's been fixed, and one that has not yet happened.
Thanks for your interest Dusty! I've learned to order 4 at a time, and that's a GOOD thing! But unless there is more interest - I'm done now!
