OregonRookie wroteWhat is the best way to do beveled cuts on the Shopsmith? Tilting the table to at 45 seems awkward and dangerous so I figure I am doing something wrong. Maybe I should just put a finer blade on my miter saw.
I think the weakest part of the shopsmith system is the tilting table design. It works well on shorter lengths but you reach the limits in short order. (Picture frame sizes work well, that sort of size anyway.) I have no issues with rip cuts as long as you can support the work.
I have several compound miter box saws and will use them over the shopsmith for most cuts (within the limits of those saws). The cheapest upgrade to any saw is a really good blade.
If you need 4' x 4' piece of plywood with 45 deg beveled edges a clamping system with a circular saw or router is the way to go... or someones regular table saw. While yes it can be done on a shopsmith most people will not even try it because of how hard it would be to do.
Now I really love my shopsmiths but knowing the limits of a tool is also importain.
