Quill fell out
Quill fell out
I'm fairly new to ShopSmith, having just bought a '54 Greenie last fall. I was using it in the drill press position yesterday and the quill came crashing down onto the piece I was drilling. I ran over to the wall and unplugged it. The quill went back into the headstock easily, but I don't want to use it until I get an idea of the cause. I searched the forums but couldn't find an answer. Would someone please advise me on how to proceed with troubleshooting this problem. Thank you for your help.
Re: Quill fell out
As for 'falling out', there is a small half dog set screw on the top of the headstock. The 'dog' part rides in a partial groove in the quill body. The set screw prevents the quill body from rotating, but the groove stops before the quill will move out of the bore. Take care to insure the groove is centered below the set screw hole. The groove walls may be scarred - clean that up with a small file.
Also the quill return spring should prevent it from falling at all. Fixing that can be an exercise it anger prevention so go take care of that set screw first.
If the set screw is missing, come back and we can post a picture of one.
Re: Quill fell out
The set screw is there. I'll take a look see at the groove. Thank you so much for the tips.
Re: Quill fell out
Take the time to view this Sawdust Session and then I believe you will know how to resolve your problem.RxRick wrote:I'm fairly new to ShopSmith, having just bought a '54 Greenie last fall. I was using it in the drill press position yesterday and the quill came crashing down onto the piece I was drilling. I ran over to the wall and unplugged it. The quill went back into the headstock easily, but I don't want to use it until I get an idea of the cause. I searched the forums but couldn't find an answer. Would someone please advise me on how to proceed with troubleshooting this problem. Thank you for your help.
You said the quill went back in easily. When you put it back, did you adjust the set screw on top of the headstock? Do you see a setscrew on top of the headstock?
http://www.shopsmithacademy.com/SS_Arch ... enance.htm
Being a new member of the Shopsmith community, I suggest that you spent some time browsing through the "Sawdust Sessions" and "Video Shop Tips".
Welcome to the forum. I hope this helped.
Re: Quill fell out
Make sure the set screw is the correct one. It should be a dog point type. That is it should have a a round extension below the threaded area that will resemble a dowel. They can be obtained from SS or McMaster-Carr on the internet.
- Ed in Tampa
Re: Quill fell out
Bill check your PM I sent you a message.wa2crk wrote:Make sure the set screw is the correct one. It should be a dog point type. That is it should have a a round extension below the threaded area that will resemble a dowel. They can be obtained from SS or McMaster-Carr on the internet.
Re: Quill fell out
Re: Quill fell out
There may be two things wrong. Could be the set screw but also it could be the depth stop. If the set screw is not set correctly AND the depth stop does not limit the travel at 4" then the quill could drop out.
Re: Quill fell out
Re: Quill fell out
The depth stop should be 'free wheeling' unless specifically set.(serrated washers loose)
