Hey all - I think I'm just being cheap by asking this here, but I couldn't find a downloadable manual for the SI. Picked one up used and unsure of it's history. Anyone able to give me a few pointers on if certain parts need lubrication like with the headstock? Any internal bearings I may need to be aware of?
Thanks in advance...
Speed Increaser Maintenance
Re: Speed Increaser Maintenance
Probably but only after you reveal what it is that you picked up.ferrarod wrote:Hey all - I think I'm just being cheap by asking this here, but I couldn't find a downloadable manual for the SI. Picked one up used and unsure of it's history. Anyone able to give me a few pointers on if certain parts need lubrication like with the headstock? Any internal bearings I may need to be aware of?
Re: RE: Re: Speed Increaser Maintenance
Speed Increaser. In the title too.dusty wrote:Probably but only after you reveal what it is that you picked up.ferrarod wrote:Hey all - I think I'm just being cheap by asking this here, but I couldn't find a downloadable manual for the SI. Picked one up used and unsure of it's history. Anyone able to give me a few pointers on if certain parts need lubrication like with the headstock? Any internal bearings I may need to be aware of?
The Speed Increaser has sealed bearings so the only maintenance is every ten hours thoroughly cleaning the housing & support spindle and checking the screws are all tight.
You can order a manual from Shopsmith. It is P/N 845268 Mark V Increaser Owner's Manual cost $10.49
Reference: Speed Increaser Instruction Manual page 22 Maintenance
All SPT's & 2 Power Stations
Thanks Russ - that sounds great.
If you join the Facebook group Shopsmith Owners Group you should find the SI manual in their files section.ferrarod wrote:Thanks Russ - that sounds great.
Shopsmith still sells the speed increaser disk, which is a cheap plastic disk which transfers the power from the spindle to the shaper/router arbor. This is the only 'consumable' part meant to be replaced on the speed increaser.
Geoff Baker
1951 10ER w variable speed electronic motor with reverse
1999 520 w PowerPro
Belt sander - strip sander - bandsaw - scrollsaw - jointer - overarm router - undertable router mounted on main SS saw table - speed increaser - speed reducer - forced air HEPA filter for headstock - 19" SS powered aluminum drum sander - index wheel system - lathe table crossslide vise system
1999 520 w PowerPro
