ProPlaner Setup Question
Lodgepole
Post by Lodgepole »
ProPlaner Manual: Page 10, Planer Setup, 6. Attach the V-belt...."The belt should have approximately 1/2 inch deflection on each side."
This seems like i would need a couple of more hands to be able to take this measurement. Rather than this method, can I put a straight edge on one side and measure the deflection as 1"?
Any other suggestions on how to handle this part of the setup would be greatly appreciated.
everettdavis
Re: ProPlaner Setup Question
Post by everettdavis »
Squeeze the belt together about midway on both sides with one hand.
It should deflect inward about the width of the belt on each side, no further.
Everett
Lodgepole wrote:ProPlaner Manual: Page 10, Planer Setup, 6. Attach the V-belt...."The belt should have approximately 1/2 inch deflection on each side."
The key word here is approximately. This is not a precise measurement. Do as Everett says and all will be fine.
Lodgepole
Post by Lodgepole »
Thank you both for this information!
