Tachometer
Tachometer
I recently did a teardown & reassembly on my 1985 510 and wanted to figure out how close the speed control is to the actual speed.
Posts in this forum have indicated that a handheld optical tach has been used to measure the speed, but then I got to thinking that wouldn't it be nice to have a permanent readout using an inductive tachometer. Has anyone ever tried this?
Thx,
Eric in Philly
Thx,
Eric in Philly
Re: Tachometer
In this thread about a 10ER with a 12V variable speed motor it looks like Charger1966 is using something like an automotive tach mounted on the machine for continuous monitoring.
Re: Tachometer
Thanks Ed - I will follow up with Charger1966.
Re: Tachometer
Different options out there, but if you want more of a canned solution that is already put together, you may find this website interesting:
http://www.mkctools.com/tachoptions.htm
RF Guy
Re: Tachometer
If you have an Arduino, there's a very easy and under $15 solution:
https://maker.pro/arduino/tutorial/how- ... th-arduino
1960's vintage Shopsmith Mark VII with Bandsaw, Belt Sander, Jointer
Re: Tachometer
Cool.
I just started learning Arduino so maybe I'll explore this.
SS Mark VII(sn 405025), SSband saw, SS 4" jointer, Older SS Mark V w/DC treadmill motor,
Smithy SuperShop 720, Powerkraft RAS,Craftsman RAS, Ridgid TS2412 Table Saw,
Delta 12" planer
Delta 12" planer
Re: Tachometer
Awesome ! If you need pointers, please let me know. I set this up and works fairly accurately.
Re: Tachometer
I might play around with the Arduino approach. I want something more of a stand alone tach and was thinking about something that could pick up a reflected light instead of a magnet so anything could be tested with just a little stick on foil dot. The circuit is simple enough either way. I wonder how light weight the magnet could be to trigger those Hall Effect sensors at high speed. If it was light enough it could be stuck on just like a reflective dot.
Re: Tachometer
The question not (yet) asked is why?
Re: Tachometer
I think he wants to figure out how close the speed control is to the actual speed.
I want a tachometer because I don't have one. That's a good reason to acquire any tool.
