Shaft guard
Shaft guard
Does anyone use the shaft guard item (521889)?
Re: Shaft guard
I think I know what it is, but have never seen one. I think you should include a pic, many have never seen it and might not know what it is. Is it the plastic thingy that mounts to the headstock belt cover and 'protects' the operator from hubs or empty spindles? Introduced some time AFTER 50 years of production...
Re: Shaft guard
There are pics of it in the instructions for it. I couldn't find any standalone pics.
https://www.shopsmith.com/ownersite/pro ... tGuard.pdf
RF Guy
Re: Shaft guard
Yes, I also use it. I installed mine more "permanently" with bolts and lock nuts. Drilled a hole in the top of the upper shaft guard for access with allen wrench in case I need to loosen, tighten, or remove hub. A PVC cap also slip fits over the end of the upper guard for extra protection from accidental contact.
- P6201987.JPG (83.78 KiB) Viewed 1530 times
- P6201991.JPG (78.25 KiB) Viewed 1530 times
- P6201988.JPG (81.28 KiB) Viewed 1530 times
- P6201989.JPG (70.48 KiB) Viewed 1530 times
- P6201990.JPG (67.17 KiB) Viewed 1530 times
Re: Shaft guard
OK, so when is SS gonna make a guard for the quill shaft?
Oh and the rotating quill feed shaft.
Re: Shaft guard
JPG, you asked
There are even hub guards now found on some SPT's just to keep us safe. One of my Jointers has the Dust Chute Upgrade Kit installed which has a hub guard. My 2006 Bandsaw includes a hub guard too. At some point there may even be a guard made to cover the coupler between the headstock and SPT's. Between law suits and the Consumer Products Safety Commission, safety for tools is a big deal.
kgfaro,
I have one on my Mark V made in 2006. They came stock by then. I have one for my Power Pro Headstock but haven't installed it yet. It doesn't have pre-tapped holes for it like the 2006 Belt Cover so I have to add them. I use the Power Pro Mark 7 mostly and find it helpful to have the upper hub exposed to turn the quill by hand at times. I'll have to get a Quill Twister shown at the link below if I do add it.
https://www.shopsmith.com/ownersite/cat ... wister.htm
Something about this page on the Shopsmith catalog site should be corrected. Lower on the page is an Important Note
Below is the picture shown to the right
_ .
That coupler didn't come out until 1954 after the Mark 5 was introduced and wasn't even the original coupler design. There were no SPT Couplers available or needed in 1952. They may have meant 1962 which is about the time the coupler changed to look like the ones made today. Oops
They already did. It is a bit bulky though. It's called the Lower Blade Guard and the TableOK, so when is SS gonna make a guard for the quill shaft?
kgfaro,
Note: If your early (before 1952) version Shopsmith coupler looks like the one shown in the picture at the right, you will need to order a new coupler to use the Quill Twister.
_ .
All SPT's & 2 Power Stations
Re: Shaft guard
If you're gonna do it you definitely want part #521889:
521889 Belt Cover Shaft Guard ... $4.95
It costs a lot less than 5222397:
522397 Belt Cover & Shaft Guard ... $88.07
Is the 521889 made out of plastic and the other one made out of metal? Or is the expensive one for something else?
Re: Shaft guard
edma194 wrote: ↑Fri Sep 10, 2021 3:16 pm If you're gonna do it you definitely want part #521889:
That's a good question what could the expensive one be for?
Re: Shaft guard
I have not looked but...edma194 wrote: ↑Fri Sep 10, 2021 3:16 pm If you're gonna do it you definitely want part #521889:
521889 Belt Cover Shaft Guard ... $4.95 is only the shaft guard (one item). It is plastic BTW.
522397 Belt Cover & Shaft Guard ... $88.07 Notice the & in the description. To me that means the metal belt cover for the SS head stock and the shaft guard that attaches to it (two items).
